Article ID : 00282325 / Last Modified : 18/08/2022Print
How to pair the INZONE headphones with the INZONE USB transmitter
    If your INZONE headphones or USB transmitter were replaced, you'll need to pair the headphones with the USB transmitter again:
    1. Press and hold the power button on the headset for about 2 seconds or longer, and turn off the headset.
    2. Set the USB transmitter slide switch to "PC" and connect it to a computer.
    3. Press and hold the connect button on the USB transmitter for at least 5 seconds.
    1. The USB transmitter indicator will repeatedly flash white twice
    2. Put on the headset and press and hold the power button for about 2 seconds or longer to turn on the headset's power.
    3. You should hear an audio cue that confirms the connection between the transmitter and headphones is complete. The USB transmitter will stop flashing and should light up continuously, indicating that the pairing procedure has finished.
    4. You can turn off your headphones and remove the USB transmitter to finalise.
