The settings on the INZONE Hub software don't work (e.g., Equaliser, Spatial Sound)
- To use the INZONE Hub software settings, make sure the Output of the computer is set to INZONE H9 / INZONE H7 - Game or INZONE H3. Follow these steps to set the Output on the computer:
- The App Sync Settings only works when the headphones are connected to a computer using the USB transceiver and the INZONE Hub software is running.
- The following will not work when the headphones are connected to the PlayStation 5 console or connected to any device via Bluetooth:
- Sound Settings
- Sound Profile
- Equalizer
- Spatial Sound
- Spatial Sound Personalization
- Dynamic Range Control
- Microphone Settings
- Microphone Volume
- Auto Gain Control
- Microphone Test
- Sound Settings
