Article ID : 00277921 / Last Modified : 14/11/2024Print
    LinkBuds (WF-L900): Music randomly stops playing or keeps pausing
    If the music stops playing or keeps pausing when using your LinkBuds (WF-L900), follow the steps in this article to troubleshoot this issue.
    1. Disable the Wide Area Tap function:
      1. Open the Sony | Headphones Connect app.
      2. Select the System tab.
      3. Disable the Wide Area Tap function.
      The issue is resolved
      Coughing, sneezing, and attaching or removing accessories or glasses may all be misinterpreted as a tap, causing the headphones to react as if they were Wide Area Tap actions.
      The issue is not resolved
      Go to the next troubleshooting step.
    2. Make sure that the ear fitting supporters are properly attached to the headphones, and the headphones are properly fitted in your ears.
      Note:  If the ear fitting supporters are not properly attached, the Wide Area Tap function may not work properly. Align the protruding part of the headphones with the cutout on the fitting supporter (A). Make sure to insert the fitting supporter completely, as illustrated below.
      image attaching the ear fitting supporter
    3. Check if the issue is resolved after the Speak-to-Chat function is disabled.
      2. Select the Sound tab.
      3. Disable the Speak-to-Chat function.
      The Speak-to-Chat mode activates when the headphones detect the speech of the person wearing the headphones. In rare cases, Speak-to-Chat may activate in response to vibrations caused by electric devices (e.g. electric toothbrushes, massagers or shavers) or by certain activities (e.g. brushing your teeth, coughing, or humming). If you are bothered by this function, please turn it off or set Speak-to-Chat to L Sensitivity.
    4. Clean the sensor on the headphones.
      In the default setting, music pauses when the headphones are taken off, and starts playing again after they are worn. If any dirt is attached to the sensor on the headphones, the headphones may not detect the correct action.
      image indicating the built-in sensor of the LinkBuds
      • B: Built-in sensor
      Note:  The setting above can be disabled in the System → Pauses when the headphones are taken off using the Sony | Headphones Connect app.
      The Wide Area Tap function may not react depending on the app. If this is the case, use the connected device to operate the app.
    5. Reset the headphones.
      Visit the Help Guide or view the How to reset video:
      The issue may have been caused by a temporary malfunction of the headphones.
    6. Initialise the headphones.
      Note:  Initialisation returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Visit the Help Guide or view the How to initialise video:
      The headphones may be malfunctioning and service may be required.
