Article ID : 00281160 / Last Modified : 20/07/2022Print
Unable to control volume using the multi-room group feature with Google Home app, Google Assistant or volume button
    Due to changes made by Google, you can no longer adjust the volume using the multi-room feature with the Google Home app, using a Google Assistant feature voice command, or using the volume control button of the smartphone. You will need to adjust the volume of each device individually.
