Follow these steps to troubleshoot the issue:
Before you start
Update the headphones' software to the latest version. Doing so may resolve the issue. Perform the update before proceeding.
Solution
- Check if the indicators flash when the headphones are removed from the charging case.
- Charge the headphones and the charging case, and check if the headphones turn on and the sound is heard from the headphones.
- The headphones turn on, and I can hear sound from the headphones
- The cause may have been a low battery. Wait until the headphones are fully charged.
- The headphones turn on, but I cannot hear sound from the headphones
- Go to step 3.
- The headphones do not turn on
- Charging cannot be done properly. Refer to the The headphones do not charge article.
- Reconnect the headphones and the device.
- Set the headphones into the charging case, and close the lid.
- Remove the headphones, and connect with the device again.
- I can hear sound from the headphones
- The Bluetooth connection may have been temporarily unstable.
- I cannot hear sound from the headphones
- Go to the next troubleshooting step.
- Turn up the volume on the connected device.
- The issue may have been caused because the volume was set too low.
- Go to step 5.
Reset the headphones.
Visit the Help Guide or view the How to reset video:
- The issue may have been caused by a temporary malfunction of the headphones.
Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Visit the Help Guide or view the How to initialize video:
- If you have a different smartphone, Walkman, or other device, perform a Bluetooth pairing with the headphones and one of these other devices, then check if sound is heard from the headphones.
- The playback device that was initially connected may be malfunctioning. Consult the manufacturer of the device.
- The headphones may be malfunctioning, and service may be required.
