Article ID : 00285201 / Last Modified : 20/01/2026Print
    The headphones do not charge. (WF-1000X)
    Follow these steps to troubleshoot why the headphones do not charge:
    Before you start
    Update the headphones' software to the latest version. Doing so may resolve the issue. Perform the update before proceeding.
    Solution
    1. Check if the charging indicator flashes when you set the headphones in the charging case.
      The indicator flashes
      Only charge the headphones at a temperature between 5 °C and 35 °C (41 ºF to 95 ºF). If you exceed the charging temperature range when you charge the headphones, the headphones will detect the abnormality and the indicator lights will flash. When you notice that the charging case is either too cold or too hot, leave it at room temperature for about 1 to 2 hours. If after returning to the normal charging temperature range the issue is not still resolved, service may be required.
      The indicator does not flash, but it lights up or turns off
      Go to the next troubleshooting step.
    2. Check if the indicators light up when you close the lid of the charging case, wait approximately 30 seconds, and open the lid again.
      The indicators light up
      The headphones are in the process of charging. Wait until the headphones are fully charged.
      The indicators do not light up, or light up only one side of the earbuds
      The indicators light up, and then immediately turns off
    3. Set the headphones into the charging case correctly, and check if the indicators light up.
      • Be careful not to mix the left and right sides when you place the headphones into the charging case.
      • Check that the fitting supporters are correctly fitted to the headphones:
        • If the fitting supporters are misaligned, the headphones cannot be correctly set in the charging case. Make sure the tab of the fitting supporter is inserted into the groove of the headphones.
          image attaching the arc supporter
      • Gently push the headphones with your finger until it clicks and locks into place in the charging case.
      The issue was caused because the headphones were not properly set into the charging case.
    4. Connect the supplied USB cable to the charging case, and check if the indicators light up.
      Note: Use the USB cable that is supplied with the product. Charging may not be possible with a commercially-available USB cable.
      The cause may have been a low battery. Wait until the headphones are fully charged.
    5. Clean the charging ports of the headphones, and check if the charging indicators light up.
      The charging ports were not clean and could not contact with the headphones. Wait until the headphones are fully charged.
      Note: Regular cleaning is recommended to prevent issues with charging.
    6. Reset the headphones.
      Visit the Help Guide to reset the headphones.
      The issue is resolved
      The issue may have been caused by a temporary malfunction of the headphones.
      The issue is not resolved
    7. Check if you can charge a different device with the same AC adapter or USB port.
      Use the same AC adapter or the USB port on the computer to charge a different mobile device or product.
      The mobile device or product can be charged
      The headphones and/or supplied USB cable may be malfunctioning. Service may be required.
      The mobile device or product cannot be charged
      The AC adapter or USB port may not be working. Contact the manufacturer.
    Go to the Headphones Troubleshooting Guide
