Article ID : 00294177 / Last Modified : 20/01/2026Print
    The 360 Reality Audio icon is not displayed even when I cast (play) the music using the 360 Reality Audio compatible streaming app
    Check the following to troubleshoot this issue:
    • Check that the music you are playing is compatible with 360 Reality Audio.
      Note: Please be aware that some of the music content offered in the 360 Reality Audio music streaming app is not 360 Reality Audio compatible.
    • Check that the smartphone and the speaker are connected to the same Wi-Fi network.
      Note: You cannot play 360 Reality Audio music via Bluetooth connection!
    • Make sure that your Sound Bar is updated to the latest version.
    • When you cast 360 Reality Audio music using the Amazon Music Unlimited service, select 3D Audio music in the Amazon Music app, and then tap the source device.
      A screen to select a playback device on the Amazon Music app. The device is indicated as A (square icon), B (circle icon) from top to bottom.
      A: Chromecast built-in device name (360 Reality Audio playback available)
      Note: This icon will be displayed only for Android apps.
      B: Amazon Alexa device name (360 Reality Audio playback available)
      For details, refer to our How to play 360 Reality Audio music using the Amazon Music Unlimited service article.
