Article ID : 00265014 / Last Modified : 20/01/2026Print
The Battery share function is not available for wireless charging
    You can't wirelessly charge another device from the battery of your phone due to the following conditions.
    • The Battery share function can't be used while charging your Xperia phone wirelessly.
    • If you start charging your Xperia phone while the Battery share is enabled, the Battery share function will stop.
    • The Battery share function doesn't start automatically, even if you stop charging your Xperia phone.
