Article ID : 00264053 / Last Modified : 04/09/2023Print
There are lines or smears on the shutter curtain
    The streaky lines and smears that may appear when the shutter curtain is closed are patterns made by the carbon material used in the shutter blades. Due to individual differences, the markings may not be the same and depend on the angle of view.
    The markings are patterns from the material and will not affect the performance of the camera.
    • When viewed from the front
      A photograph of the shutter seen from the front
    • When viewed from above at an angle
      A photograph of the shutter seen from above at an angle
