Article ID : 00176692 / Last Modified : 23/03/2021
Are there any restrictions on use of the electronic shutter?
    The following functions are unavailable when the Shutter Type is set to Electronic Shut.
    NOTE: Some functions are not available, depending on the model.
    • Flash shooting
    • Long Exposure NR
    • Bulb shooting
    • Continuous shooting with a shutter speed longer than 1/8 second
    • High ISO sensitivity settings of above ISO 25600
    • Shooting with remote release when FA-WRC1M Wireless Radio Commander is attached to the Multi Interface Shoe
    • Smart Zoom, Clear Image Zoom, and Digital Zoom functions during Cont. Shooting
    • Anti-flicker Shoot.
    The maximum shutter speed for the electronic shutter is limited.
    • The maximum shutter speed is 1/16000 second when the shooting mode is set to one other than S (Shutter Priority)/M (Manual Exposure), and during bracket shooting with a setting other than WB bracket or DRO Bracket.
    • When the shooting mode is set to S (Shutter Priority)/M (Manual Exposure), the next available shutter speed after 1/16000 second is 1/32000 second.
    • Shutter speeds of up to 1/16000 second can be registered to Recall Custom hold.
    • A shutter speed of up to 1/16000 second can be registered as the shutter speed at which the ISO sensitivity starts changing (ISO AUTO Min. SS).
    Shooting results when using the electronic shutter
    • A belt-like contrast may be recorded in images shot under a momentary light (such as the firing of another camera’s flash) or a flickering light such as fluorescent lighting.
    • When using the electronic shutter, the micro rolling shutter phenomenon (slight distortion or aliasing caused by high-speed readout) may occur under the following conditions.
      • The subject is moving very quickly within the imaging area.
      • A flash light from another photographer was recorded in the image.
      • The illumination from a spotlight, etc. or light source is moving very quickly within the imaging area.
