Article ID : 00259859 / Last Modified : 25/05/2022
The power of the device does not link with the TV's.
    Check the following:
    • The TV supports the Control for HDMI function.
    • The ARC-compatible HDMI input jack on the TV is connected to the HDMI output jack on the audio device.
    • Check that the Control for HDMI function is active both on the TV and the audio device.
    • The speaker settings of the TV are configured to output sound from the audio device. If sound is output from the TV speakers, change the speaker settings of the TV.
    * For details on TV specifications and settings, refer to the operating instructions supplied with your TV.
