Article ID : 00252721 / Last Modified : 28/01/2021Print
    Can I adjust the stand of my Sony Android TV?
    Some Sony Android TVs from the A8/A9x and XH90/92 series either come with differently positioned fixed stands or allow you to adjust the feet beneath the TV.
    Picking the right stand position for your TV is particularly important if you're using a soundbar with your TV or if the TV stands on a narrow surface. Find out what options are available by clicking on your series below:
    Available stand options
    Related article
    How to change table top stand height and position after set up
