What is the right side of the headphones used for? Sidetone function explained
The right side is exclusively used for the Sidetone function. You can talk using the microphone on the left side of the headphones.
What is the sidetone function?
The Sidetone function is a feature that makes it easier to talk using the headphones. This function helps the headphone microphone to pick up sounds and replay your voice naturally.
