What TV models are compatible with DVB-T2 and HEVC MAIN 10?
What is DVB-T2 and HEVC MAIN 10?
DVB-T2 is an abbreviation for Digital Video Broadcasting — Second Generation Terrestrial, while HEVC MAIN 10 is the 10-bit version of the High-Efficiency Video Coding (HEVC) video transcoding standard.
Due to changes in the broadcasting networks, terrestrial digital television signals will eventually switch to different video codecs. This article shows all the models compatible with DVB-T2/HEVC MAIN 10 (10Bit).
What are the compatible Sony TVs for DVB-T2 Tuner with H.265/HEVC MAIN 10 (10-Bit)?
All Sony TVs from 2017 line-up and later are compatible except for the models in the note below the table.
If you have a compatible TV but are unable to receive a signal, please re-tune your TV.
- How do I tune or retune my Sony's Android TV (Analogue/Cable/Terrestrial Guide)?
- How do I tune or retune my Sony LCD TV (Analogue/Cable/Terrestrial Guide)?
2014 - All 4K UHD desktop models (with current software version) 1 |
2015 - all models with Android operating system (with software update) 2 |
2016 - all models ** |
2017 - all models *** |
2018 - all models **** |
2019 - all models *****
2020 – all models |
Important information to note:
- 1 Software version 3.004 (or higher), released on 21st March 2017.
- 2 Software version 5.381 (or higher), released on 9th March 2018.
- (**) - (***) - (****) The list above does not include all the UK and RU models. Models purchased outside of Europe may not be DVB-T2 compatible.
- From 2017 line-up and later: all models are compatible except for the models in the note.
