Article ID : 00242776 / Last Modified : 30/08/2021Print
Why does the ink ribbon run out before the paper? Is this a fault?
    In most cases, this is caused by a dirty sensor that reads the barcode on the ink ribbon, rather than a fault.
    The sensor lens needs cleaning. Contact your dealer.
