I need help with my MySony account or with the registration of my product in MySony
This page will give you information about MySony and help you solve issues linked to product registration and to your account.
- Login issues: I can't access my account
- What if I've forgotten my security question?
- My account is locked
- I want to update my account
- Can I change my password?
- I want to delete my account
- What if I can't find the product I want to register?
- Sony Mobile & Sony Professional registration
- How can I update or remove a product?
- I cannot register because the site doesn't accept my serial number
- How can I check if my product registration was successful?
Account
If you cannot access your account, please make sure that
- you've entered your e-mail address correctly
- if your e-mail address is correct and you can't remember your password, please use the Forgot your password function. You will need to answer your security question and give your date of birth in order to reset your password.
There are 2 options if you're locked out of your account:
- Contact us! Our contact centre agents can unlock your account. In the future we will implement a different security system to avoid this.
- Contact us! (UK)
- Contact us! (Ireland)
- Contact us! (Estonia)
- Contact us! (Latvia)
- Create a new account with a different e-mail address.
If you try and fail many login attempts, your account will be locked for 120 minutes.
After that set period of time, you can try again.
- Make sure the Caps Lock or Num Lock on your keyboard are not interfering with the way you are entering your password.
- You can try to reset your password after 120 minutes using the Forgot your password feature.
To update your e-mail or address:
- Login to your My Sony account
- Go to the My account section
- Proceed with updating the fields concerned
To change your password, please:
- Scroll down until you find the Change my password section
- Enter your old and new passwords
- Confirm by clicking on Change my password
We would be sorry to see you go, but you can delete your account by following these steps:
- Click on account information
- Scroll down all the way to the bottom and select Remove account
Products
- First of all, please make sure the product you want to register is a Sony Electronic product. If you have a Sony Mobile device (Xperia) or a Sony professional product, you should visit one of the following pages:
- Sony Mobile
(Click on the portrait icon on the upper right hand side of the page to log in) - Sony Professional
- Sony Mobile
- If you're certain your product is a Sony Electronics product, and you've manually typed the product name but cannot find it, please try to find it using the drop-down menu.
- If the first two options do not help, your product might be missing in our database. Please contact us to confirm this.
- Contact us! (UK)
In order to update or remove a product from your account, please proceed as follows:
- Go to My products and select the related product
- Press 'Change my product details' or 'Remove the product'
Luckily, the serial number is not a mandatory field, so you can proceed without it.
If you're unsure on where to find your serial number, please check our help page. It shows you where you can find both your model and serial number.
- Go to the "My products" tab
- Verify if the product is available or not.
- If it is not available or hasn't been updated, please try to register the product or update again. If you still cannot manage to register your product, please contact us.
- Contact us! (UK)
