Article ID : 00237315 / Last Modified : 27/03/2020
The device gets hot
    • If you use your device to talk, transmit data, or play games or music for an extended time, the device may get hot. This is normal because in these conditions the device uses more power than usual and therefore generates more heat.
    • Update your device to ensure that you have optimal performance and the latest enhancements.
