The WebLink displays an error or USB connection is not detected
If the WebLink function cannot be used, check the following.
Are any of the errors below displayed?
- USB device not supported. For detail on the compatible devices, visit the support site on the last page in the supplied manual
Install the WebLink Host app to your smartphone from the Abalta website.
If you have already installed the WebLink Host app, restart your smartphone and reconnect the USB cable.
A WebLink error message is displayed on the head unit screen?
Confirm the meaning of the message on the Abalta WebLink FAQ website.
Are you using an iPhone and the USB connection cannot be detected?
If the iPhone is locked, the USB connection cannot be detected.
Unlock your iPhone to solve this.
Are you using an iPhone and see this error?
- "Resume a WebLink compatible app to continue" is displayed while using the WebLink app
Keep the WebLink Host app in the foreground of the screen while using the WebLink function.
