Article ID : 00236052 / Last Modified : 19/03/2025Print
    Sound is interrupted or noise occurs while playing music on my earbud headphones
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article.
    The headphones use a left and right simultaneous Bluetooth transmission method. This means the Bluetooth connection stability is improved compared to other more conventional headphones. However, the sound may be intermittent, or no sound may come out at all, in some situations. For details, check the following:
    When is the noise most likely to occur?
    Troubleshooting
    If the issue is still not resolved:
