Article ID : 00236094 / Last Modified : 28/02/2023Print
Can I connect (pair) my headphones to multiple Bluetooth devices at the same time?
Does the headset support multiple device pairing or multipoint connection?
    The headphones can be registered (paired with) up to eight different devices but can connect with only one device at a time. Therefore, "Multipoint" connections aren't supported. When you've separately paired the headset with two or more devices, you'll need to switch the Bluetooth™ connection to the desired device.
