Article ID : 00240488 / Last Modified : 21/01/2020
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2016 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For safety reasons and to ensure correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      1. W (width)
      2. H (height)
      3. screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third-party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility Chart.
      Ac Power adapter size
      1. W (width)
      2. H (height)
      3. D (depth)
    Compatibility chart
    2016 models
    Series Name
    Model Name
    Inches
    Compatible Wall-Mount Bracket
    Screw hole size
    (W x H) mm
    Screws (Supplied with Wall-Mount Bracket)
    Length of power cord (mains lead)
    Weight of TV without Stand
    ZD9 Series
    KD-100ZD9
    100
    600 x 400
    2.0 m
    118.6 kg
    KD-75ZD9
    75
    400 x 300
    1.5 m
    41.3 kg
    KD-65ZD9
    65
    SU-WL450 *1
    400 x 300
    +PSW 6x20, +PSW 6x50
    1.5 m
    32.0 kg
    XD93xx_XD94xx Series
    KD-75XD9405
    75
    Wall-Mount Bracket accessories supplied with your TV
    400 x 300
    1.5 m
    38.7 kg
    KD-65XD9305
    65
    SU-WL450 *1
    300 x 200
    DC Cable length of AC adapter
    2.5 m
    Length of AC Power Cord
    2.0 m
    AC Power adapter size (W x H x D)
    287 x 75 x 32.5
    28.9 kg
    KD-55XD9305
    55
    SU-WL450 *1
    300 x 200
    2.5 m
    2.0 m
    287 x 75 x 32.5
    22.0 kg
    XD85xx Series
    KD-85XD8505
    85
    400 x 300
    1.5 m
    60.2 kg
    KD-75XD8505
    75
    400 x 300
    1.5 m
    33.4 kg
    KD-65XD8505
    KD-65XD8577
    KD-65XD8599
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    20.3kg
    KD-55XD8505
    KD-55XD8577
    KD-55XD8588
    KD-55XD8599
    55
    200 x 200
    1.5 m
    0.5 m
    192 x 80 x 32
    15.1kg
    XD83xx Series
    KD-49XD8305
    49
    SU-WL450 *1
    200 x 300
    1.5 m
    0.5 m (Russia: 1.5 m)
    192 x 80 x 32
    13.2 kg
    KD-43XD8305
    43
    100 x 200
    1.5 m
    12.3 kg
    XD80xx Series
    KD-55XD8005
    55
    SU-WL450 *1
    200 x 200
    1.5 m
    192 x 80 x 32
    14.7 kg
    KD-49XD8005
    KD-49XD8077
    KD-49XD8088
    KD-49XD8099
    49
    200 x 300
    1.5 m
    0.5 m
    192 x 80 x 32
    13.2 kg
    KD-43XD8005
    KD-43XD8077
    KD-43XD8088
    KD-43XD8099
    43
    100 x 200
    1.5 m
    12.3 kg
    XD75xx Series
    KD-65XD7504
    KD-65XD7505
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    21.5 kg
    XD70xx Series
    KD-55XD7004
    KD-55XD7005
    55
    SU-WL450 *1
    200 x 200
    1.5 m
    16.9 kg
    KD-49XD7004
    KD-49XD7005
    49
    200 x 200
    1.5 m
    13.2 kg
    SD85xx_SD80xx Series
    KD-65SD8505
    65
    SU-WL450 *1
    300 x 200
    1.5 m
    29.4 kg
    KD-55SD8505
    55
    200 x 200
    1.5 m
    226 x 75 x 38
    21.4 kg
    KD-50SD8005
    50
    200 x 200
    1.5 m
    192 x 80 x 32
    16.7 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
