The compatibility chart of the 3D glasses for Android TV (2016/2015 models)
- I want to check the compatible optional 3D glasses for my BRAVIA TV.
- I purchase a new 3D supported BRAVIA TV. Can I continue to use the 3D glasses that I am using for my older TV on the new TV?
You will require a compatible 3D glasses for watching 3D movies with 3D supported Android TV (2016/2015 models).
Check the following compatibility chart to confirm which 3D type corresponds to your TV and the compatible 3D glasses for your TV.
2016 models
3D function supported BRAVIA TV | 3D type | Communication system | Compatible 3D glasses | |
Series | Model name | |||
ZD9 Series | KD-100ZD9 KD-75ZD9 KD-65ZD9 |
Active | RF (Bluetooth) | TDG-BT500A / TDG-BT400A (*1) |
XD93xx_XD94xx Series | KD-75XD9405 KD-65XD9305 KD-55XD9305 |
2015 models
For AP Region:
X93xxC_X94xxC Series | KD-75X9400C KD-65X9300C KD-55X9300C |
X90xxC_X91xxC Series | KD-75X9100C | |||
KD-65X9000C KD-55X9000C |
Passive | IR | TDG-500P | |
X85xxC Series | KD-75X8500C KD-65X8500C KD-55X8500C |
S85xxC Series | KD-65S8500C KD-55S8500C |
W85xC Series | KDL-75W850C KDL-65W850C |
W80xC Series | KDL-55W800C KDL-50W800C KDL-43W800C |
*1 Supplied as an accessory depending on the model/region/country
X90xxC_X91xxC Series | KD-75X9105C | Active | RF (Bluetooth) | TDG-BT500A / TDG-BT400A (*1) |
KD-65X9005C KD-55X9005C |
X85xxC Series | KD-65X8508C KD-55X8508C KD-65X8507C KD-55X8507C KD-75X8505C KD-65X8505C KD-55X8505C KD-75X8501C KD-65X8501C KD-55X8501C |
S85xxC Series | KD-75X9105C | |||
S80xxC Series | KD-65S8005C KD-55S8005C |
W85xC Series | KDL-65W859C KDL-65W858C KDL-65W857C KDL-75W855C KDL-65W855C |
W80xC Series | KDL-55W809C KDL-50W809C KDL-43W809C KDL-55W808C KDL-50W808C KDL-43W808C KDL-55W807C KDL-50W807C KDL-43W807C KDL-55W805C |
