Article ID : 00240497 / Last Modified : 21/01/2020
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2017 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For safety reasons and to ensure correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      1. W (width)
      2. H (height)
      3. screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third-party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility Chart.
      Ac Power adapter size
      1. W (width)
      2. H (height)
      3. D (depth)
    Compatibility chart
    2017 models
    Series Name
    Model Name
    Inches
    Compatible Wall-Mount Bracket
    Screw hole size
    (W x H) mm
    Screws (Supplied with Wall-Mount Bracket)
    Length of power cord (mains lead)
    Weight of TV without Stand
    A1 Series
    KD-65A1
    65
    SU-WL450
    400 x 200
    +PSW 6x20, +PSW 6x50
    2 m
    29.8 kg
    KD-55A1
    55
    400 x 200
    2 m
    25.0 kg
    XE93xx_XE94xx Series
    KD-75XE9405
    75
    SU-WL845
    400 x 300
    +PSW 6x13, +PSW 6x23
    1.5 m
    42.8 kg
    KD-65XE9305
    65
    SU-WL845
    400 x 300
    1.5 m
    38.2 kg
    SU-WL450 *1
    400 x 300
    KD-55XE9305
    55
    SU-WL840
    300 x 300
    DC Cable length of AC adapter
    2.5 m
    Length of AC Power Cord
    2.0 m
    AC Power adapter size (W x H x D)
    287 x 75 x 32.5
    28.6 kg
    SU-WL450 *1
    300 x 300
    XE90xx Series
    KD-75XE9005
    75
    400 x 400
    1.5 m
    33.2 kg
    KD-65XE9005
    65
    SU-WL450 *1
    300 x 300
    2.5 m
    2.0 m
    287 x 75 x 32.5
    22.0 kg
    KD-55XE9005
    55
    300 x 300
    1.5 m
    0.5 m (Russia: 1.5 m)
    228 x 75 x 38
    16.9 kg
    KD-49XE9005
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    228 x 75 x 38
    12.6 kg
    XE85xx Series
    KD-65XE8505
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    21.0 kg
    KD-55XE8505
    55
    200 x 200
    1.5 m
    18.6 kg
    XE80xx Series
    KD-49XE8005
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    0.5 m
    (170 x 85 x 40) or (191 x 80 x 39)
    12.2 kg
    KD-43XE8005
    43
    100 x 200
    1.5 m
    0.5 m
    10.1 kg
    XE70xx Series
    KD-65XE7005
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7005
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7005
    49
    200 x 200
    1.5 m
    (161 x 68 x 36) or (170 x 85 x 40)
    11.4 kg
    KD-43XE7005
    43
    100 x 200
    1.5 m
    161 x 68 x 36
    9.3 kg
    KD-65XE7003
    65
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7003
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7003
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7003
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    KD-65XE7002
    65
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7002
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7002
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7002
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    KD-55XE7000
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7000
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7000
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    WE75x Series
    KDL-49WE753
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    0.5 m
    (155 x 63 x 32) or (153 x 51 x 35)
    11.5 kg
    KDL-43WE753
    43
    100 x 200
    1.5 m
    0.5 m
    9.1 kg
    KDL-49WE755
    49
    200 x 200
    1.5 m
    (157 x 65 x 32) or (151 x 65 x 32)
    11.5 kg
    KDL-43WE755
    43
    100 x 200
    1.5 m
    9.1 kg
    KDL-49WE750
    49
    200 x 200
    1.5 m
    0.5 m
    11.5 kg
    KDL-43WE750
    43
    100 x 200
    1.5 m
    0.5 m
    9.1 kg
    WE61x_WE66x Series
    KDL-49WE665
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    11.4 kg
    KDL-40WE665
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-49WE663
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KDL-40WE663
    40
    100 x 200
    1.5 m
    (129 x 56 x 34) or (110 x 63.5 x 31)
    8.1 kg
    KDL-49WE660
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KDL-40WE660
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-32WE615
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    KDL-32WE613
    32
    100 x 200
    1.5 m
    5.8 kg
    KDL-32WE610
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    RE4xx Series
    KDL-40RE453
    40
    SU-WL450 *1
    100 x 200
    1.5 m
    8.1 kg
    KDL-40RE455
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-40RE450
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-32RE403
    32
    100 x 200
    1.5 m
    5.8 kg
    KDL-32RE405
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    KDL-32RE400
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
