Article ID : 00240523 / Last Modified : 21/01/2020
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2019 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For safety reasons and to ensure correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      1. W (width)
      2. H (height)
      3. screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third-party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility Chart.
      Ac Power adapter size
      1. W (width)
      2. H (height)
      3. D (depth)
    Compatibility chart
    2019 models
    Series Name
    Model Name
    Inches
    Compatible Wall-Mount Bracket
    Screw hole size
    (W x H) mm
    Length of power cord (mains lead)
    Weight of TV without Stand
    AG9 SeriesKD-77AG977SU-WL450 *1
    SU-WL850
    300 x 3002 m35.3 kg
    KD-65AG965SU-WL450 *1
    SU-WL850
    300 x 3002 m21.2 kg
    KD-55AG955SU-WL450 *1
    SU-WL850
    300 x 3002 m18.7 kg
    AG8 SeriesKD-65AG865SU-WL450 *1
    SU-WL850
    300 x 3002 m20.3 kg
    KD-55AG855SU-WL450 *1
    SU-WL850
    300 x 3001.5 m17.6 kg
    XG9505 SeriesKD-85XG950585SU-WL450 *1400 x 4002 m46 kg
    KD-75XG950575SU-WL450 *1400 x 3001.5 m35.2 kg
    KD-65XG950565SU-WL450 *1300 x 3001.5 m23.5 kg
    KD-55XG950555SU-WL450 *1300 x 3001.5 m18 kg
    XG9005 SeriesKD-49XG900549SU-WL450 *1200 x 2001.5 m13.5 kg
    XG8796 SeriesKD-75XG879675SU-WL450 *1400 x 3001.5 m37.8 kg
    KD-65XG879665SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG879655SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8599 SeriesKD-75XG859975SU-WL450 *1400 x 3001.5 m37.8 kg
    KD-65XG859965SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG859955SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8596 SeriesKD-85XG859685SU-WL450 *1400 x 4001.5 m46.5 kg
    KD-75XG859675SU-WL450 *1400 x 3001.5 m37.8 kg
    KD-65XG859665SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG859655SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8588 SeriesKD-75XG858875SU-WL450 *1400 x 3001.5 m37.8 kg
    KD-65XG858865SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG858855SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8577 SeriesKD-65XG857765SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG857755SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8505 SeriesKD-75XG850575SU-WL450 *1400 x 3001.5 m37.8 kg
    KD-65XG850565SU-WL450 *1300 x 3001.5 m25.3 kg
    KD-55XG850555SU-WL450 *1300 x 2001.5 m18.7 kg
    XG8399 SeriesKD-49XG839949SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    Length of AC Power Cord
    0.5 m
    AC Power adapter size (W x H x D)
    (191 x 80 x 39) or (170 x 85 x 40)
    13.2 kg
    KD-43XG839943SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XG8396 SeriesKD-49XG839649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XG839643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XG8388 SeriesKD-49XG838849SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XG838843SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XG8377 SeriesKD-49XG837749SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XG8305 SeriesKD-49XG830549SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XG830543SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XG8196 SeriesKD-65XG819665SU-WL450 *1300 x 3001.5 m20.9 kg
    KD-55XG819655SU-WL450 *1200 x 2001.5 m16.1 kg
    KD-49XG819649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (158 x 70.5 x 35) or (155 x 67 x 36.5)
    11.8 kg
    KD-43XG819643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.6 kg
    XG8096 SeriesKD-75XG809675SU-WL450 *1300 x 3001.5 m30.7 kg
    KD-65XG809665SU-WL450 *1300 x 3001.5 m20.9 kg
    KD-55XG809655SU-WL450 *1200 x 2001.5 m16.1 kg
    KD-49XG809649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m (Russia: 1.5 m)
    11.8 kg
    KD-43XG809643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    9.6 kg
    XG7096 SeriesKD-65XG709665SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG709655SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG709649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    11.9 kg
    KD-43XG709643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7093 SeriesKD-65XG709365SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG709355SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG709349SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    11.9 kg
    KD-43XG709343SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7077 SeriesKD-65XG707765SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG707755SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG707749SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    KD-43XG707743SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7073 SeriesKD-65XG707365SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG707355SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG707349SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    11.9 kg
    KD-43XG707343SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7005 SeriesKD-65XG700565SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG700555SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG700549SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    11.9 kg
    KD-43XG700543SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7004 SeriesKD-65XG700465SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG700455SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG700449SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    KD-43XG700443SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7003 SeriesKD-65XG700365SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG700355SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG700349SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    11.9 kg
    KD-43XG700343SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    XG7002 SeriesKD-65XG700265SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55XG700255SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49XG700249SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    11.9 kg
    KD-43XG700243SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32)
    9.7 kg
    WG665 SeriesKDL-50WG66550SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (170 x 85 x 40) or (191 x 80 x 39)
    11 kg
    KDL-43WG66543SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    (137 x 60 x 30)
    7.8 kg
    WG663 SeriesKDL-50WG66350SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11 kg
    KDL-43WG66343SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (130 x 56 x 30) or (129 x 56 x 34)
    7.8 kg
    ZG9 SeriesKD-98ZG998-600 x 4002 m94.2 kg
    KD-85ZG985SU-WL450 *1400 x 4002 m71.7 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
    For details about the screws, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
