Article ID : 00230200 / Last Modified : 22/08/2024Print
    What functions are supported on each of the HDMI terminals?
    The functions supported by each of the HDMI ports are listed below:
    ZH8 series
    FunctionsHDMI 1HDMI 2HDMI 3HDMI 4
    8K 24p/25p/30p/50p/60p signal *1---
    4K 100p/120p signal *1---
    4K 24p/25p/30p/50p/60p signal *2
    HDR
    HDCP2.3
    MHL----
    ARC(eARC)---
    *1
    • Use a Premium High-Speed HDMI cable which supports Enhanced format (18Gbps).
    • Some HDMI devices that output an 8K signal require a 48Gbps HDMI cable. In that case, use a 48Gbps HDMI cable.
    • Set the HDMI signal format for the HDMI 4 port to either Enhanced format (8K), or Enhanced format (Dolby Vision™).
    *2
    • Set the HDMI signal format for the connected HDMI port to either Enhanced formatEnhanced format (8K), or Enhanced format (Dolby Vision).
    ZG9 series
    8K 24p/30p signal (*1)---
    4K 100p/120p signal (*1)---
    4K 24p/30p/50p/60p signal (*2)
    HDR
    HDCP2.3
    MHL®----
    ARC(eARC)---
    *1
    *2
