Article ID : 00195653 / Last Modified : 21/09/2023Print
What signal or format is supported on each of the TV HDMI terminals?
Which HDMI terminals do support enhanced format (18Gbps / 18Gbps or above)?
    Click or tap the model year and letter series of your Android TV™ or Google TV™ to expand and check the functions supported by each of the HDMI® ports.
    2022 K series models
    2021 J series models
    2020 H series models
    2019 G series models
    2018 F & XF series models
    2017 A & XE series models
    2016 ZD & XD & SD series models
    2015 C series models
    Notes:
