Article ID : 00206853 / Last Modified : 25/05/2022Print
Can I use the Bluetooth function of my smart speaker when it is not connected to a network?
    You can't use the Bluetooth function without an established Wi-Fi connection.
    Connect it to an active network during initial setup, then pair and connect it to a Bluetooth device.
    For LF-S50G:
    •  If network connection shuts off after initial setup, connection and playback via Bluetooth are possible. However, the speaker will power off one hour later.
