Article ID : 00201284 / Last Modified : 19/01/2026Print
    How to avoid water damage for the WF-1000X
    If moisture or water enters the inside of the product, internal components may short-circuit, and the headset and charging case may corrode.
    Also, depending on how you handle the headset, it may become wet without you noticing, which may lead to damage.
    Check our article to avoid water damage and boost the longevity of your WF-1000X.
    Precautions
    Cases in which water damage occurs
    Examples of corrosion
    Precautions
    Observe the following points to protect your device from water damage:
    1. Do not operate with wet hands.
    2. Do not leave the device in a highly humid location for a long time.
    3. Avoid using the headset in the bathroom or other environments where it may get wet.
      Don't use the WF-1000X in water conditions
    IMPORTANT POINT
    It happens to the best of us: the headset is left in a pocket and washed, submerging it for an extensive period of time.
    When water or other liquids are the reason for damage, the product warranty becomes inapplicable. In such cases, a repair will incur a cost, even if within the warranty period.
    Also, depending on the damage, repair may not be possible (total loss).
    Please use appropriate caution when handling the device.
    1. Rain or other water drops seep into the headset from the space
    2. A drink is spilt onto the headset, or the headset is dropped in water causing it to become submerged
    3. Condensation occurs inside the headset due to sweat, humidity, or other factors
    1. Rain or moisture seeps into the headset
      Even though unintentional, the following reasons are factors that may cause the headset to become wet:
      • Operating the headset in the rain and rainwater splashes onto it.
      • After washing your hands or working with water in the kitchen, operating the headset without thoroughly wiping the water from your hands.
      Even the slightest amount of water can enter the inside of the device from the smallest space through what is called capillary action.
      Also, water left on the metal terminals can cause rust, which may result in damage.
      What is capillary action?
      Capillary action is a phenomenon where liquid moves along thin, hair-like spaces by the force of the surface tension of the liquid. An example of capillary action can be seen by standing two sticks together and applying water at the tip of the sticks. The water will travel up the margin between the sticks. If liquid attaches to a small space, such as the seams of the device, it may enter the inside of the device through capillary action and result in unintended damage.
      Locations where water may enter the device
      [A]: Microphone
      [B]: Exterior seams
      [C]: Terminals
      [D]: Spaces around the buttons
    2. A drink is spilt onto the headset, or the headset is dropped in water causing it to become submerged, and the water may enter inside the headset.
      • Inadvertently spilling your drink.
      • Leaving the device in your pocket and wash your clothes.
      • Dropping the device in water when placing it near a sink, bath, toilet, water tank, or other containers of water.
      If water or other liquid enters the headset, it may be damaged. Immediately stop using the device, turn off the power, and consult your Sony Service Center.
    3. Condensation occurs inside the headset due to sweat, humidity, or other factors causing it to become wet unexpectedly.
      • Placing the headset in the shirt pocket of clothing you have perspired in.
      • Entering a heated room from outside where it is cold. Or, exiting a well-cooled room to outside where it is hot.
      • Placing a cooled plastic bottle into your bag along with your device.
      • Leaving the device in the bathroom or other environments with high humidity for a long time.
      Repeated slight moistening due to water drops or moisture forming inside the device will cause the internal parts to corrode over time. Avoid using or leaving the device in environments subject to drastic changes in temperature or high humidity.
      Also, if condensation occurs, leave the power of the device off until it is fully dry.
    • Corrosion of the terminals
      The headset terminals corrode and blue coloured rust (copper rust) forms.
    • Corrosion of the charging case
      The headset terminals are placed in the charging case while wet and blue coloured rust (copper rust) forms.
