Article ID : 00198349 / Last Modified : 16/01/2026Print
Sound cuts out on the headphones (WH-L600)
    Depending on the product environment, distorted or intermittent sound (sometimes with some sort of noise) can occur.
    This can have several reasons: check the following issues and try their solutions.
    • The battery of the headphones might be low
      • Sufficiently charge the headphones battery
    • Check your environment
      • Make sure there are no other wireless devices using the 2.4 GHz wireless frequency band (or a microwave oven) active around the processor and headphones.
      • Try changing the position of the processor
    • You might have selected a different input
      • When the input of the processor is set to [ANALOG], set the GAIN switch on the processor to [LO].
    • The volume level might be too loud and causes the sound to distort
      • If you connect the headphone jack of the AV device to the AUDIO IN jack of the processor, decrease the volume level on the connected AV device.
    • The audio output signal frequency is too high
      • This system is compatible with 96 kHz. Set the output signal to 96 kHz on the device connected to the processor. When inputting a 192 kHz signal, a disturbing sound may be output for a moment. It is not a malfunction.
    • Try the OPT terminal
      • If there is an OPT terminal on the connected device, use an OPT cable to connect the device to the processor, and set the input of the processor to OPTICAL.
    • Is the power indicator still off after you have sufficiently charged the battery?
      • Take your headphones to your nearest Sony dealer.
