Article ID : 00197502 / Last Modified : 04/08/2020
Pairing procedure for Android mobile devices (smartphones, tablets, etc.)
    Instructions for pairing an Android device with your Bluetooth audio device:
    1. On your Android device, swipe up from the bottom of the screen.
    2. Select Settings.
    3. Select Connected devices or Device connection.
      NOTE: If these options are not displayed, go to step 5.
    4. Select Connection preferences.
      NOTES:
      • If Connection preferences is not displayed, proceed to the next step.
      • If Pair new device is displayed, select it, and proceed to step 7.
    1. Select Bluetooth.
    1. Set the Bluetooth function to ON.
      NOTE: If the Bluetooth function is already set to ON, set it to OFF and then back to ON again.
    1. On the list of available devices, select the name of the device you want to pair.
    1. Select PAIR.
    1. When the pairing process is complete, the word Active will be displayed below the device name.
      NOTE: If a passkey (or passcode, PIN code, PIN number, password, etc.) input is required, input 0000.
