This symptom occurs when more than one USB device is connected via the USB port. This symptom will also occur during the following conditions:
- USB device is not connected
- During recording on HDD or other USB devices
To resolve this issue, please connect one USB device and select [Programme List Transfer] > [Settings] > [Channel setup] > [Digital setup] > [Technical set-up] > [Programme List Transfer].
NOTE: When connecting the HDD device for recording purposes, please disconnect the HDD device if you want the [Programme List Transfer] to be activated for the USB device.
