Article ID : 00170686 / Last Modified : 16/01/2026Print
    Programme List Transfer is grayed out and cannot be selected.
    This symptom will occur in any of the following cases:
    • A USB device is not connected.
    • More than one USB device, such as an USB HDD for recording or USB memory, is connected.
    • During recording on the HDD or other USB devices.
    After checking all the issues above, check if you can select Programme List Transfer again.
    NOTE:
    • When using the USB HDD for recording, temporarily disconnect the USB cable from the TV. After performing Programme List Transfer, reconnect the cable to the TV.
    • To display the Programme List Transfer screen, perform the following procedure.
      1. Press the Home button on the remote.
      2. Select Settings.
      3.  Select Channel setup in the TV category.
      4. Select Digital setup.
      5. Select Technical set-up.
      6. Select Programme List Transfer
