Sony TV's supported file systems for external USB storage devices
You can only use USB storage devices formatted with the file systems provided by Windows (FAT - NTFS).
Please find a compatibility overview in the table below. If you're unsure about your model, have a look at our page: Understanding your TV's model name.
Overview
Supported file systems: | NTFS | FAT32 | FAT16 | exFAT |
Sony Android TV
| Yes | Yes | Yes | Yes |
Sony non-Android TV
Sony non-Android TV (R/WD/WE/XE70/WG6/XG70 series)
| Yes | Yes | Yes | No |
How can you see the format of your USB?
- Right-click the USB drive in Windows Explorer
- Select [Properties]
- Check for [File System] on the General Tab
