Cannot watch TV in 3D even though I set to 3D Display on the Home screen.
Even if you set 3D Display to 3D(Side-by-Side) or 3D(Over-Under) on the Home screen, the setting will be set to off when switching Input or starting the application.
To watch in 3D, please perform the following procedures.
- Press the ACTION MENU button on the remote control.
- Select 3D in the Display & Sound category.
- Select 3D display.
- Choose 3D(Side-by-Side) or 3D(Over-Under).
NOTE: Only some TV models support the 3D function.
