Article ID : 00122808 / Last Modified : 28/12/2020Print
How to view 3D video images on a 3D TV connected to an audio receiver or home theater system.
    IMPORTANT: Using an HDMI cable that is not high-speed will prevent the 3D signal from passing to the 3D device.
    1. Using a high-speed HDMI cable, connect a 3D-compatible player (Blu-ray Disc player, cable box, satellite receiver, etc.) to a 3D-compatible Audio/Video (A/V) stereo receiver or a Home Theater system.
    2. Using another high-speed HDMI cable, connect the 3D-compatible A/V receiver or Home Theater system to the 3D TV.
    NOTE: The Sony 3D-compatible A/V receiver or Home Theater system may require a system software (firmware) update to support 3D.
    For A/V receivers or Home Theater systems that are not 3D compatible, connect the 3D-compatible player to the 3D TV using a high-speed HDMI cable. Then connect the A/V receiver or Home Theater system to the TV using a separate audio connection.
