When the viewfinder is popped up, the monitor will not turn on. Close the viewfinder before using the camera with the underwater housing.
NOTE:
- If the camera is subjected to a strong shock after you have stored it in the underwater housing, the viewfinder may pop up and the monitor will turn off. Be sure not to subject the camera to strong shocks.
- For DSC-RX100M5(A)
To make sure that the monitor stays on while the viewfinder is popped up, select the following setting:
MENU - (Custom Settings) - FINDER/MONITOR - Monitor(Manual)
