Article ID : 00167786 / Last Modified : 16/01/2026Print
    The DOLBY D indicator or the DTS indicator on the unit does not light up
    Depending on the connected device or its settings, the output from the connected device is not in Dolby Digital or DTS format even though the connected device plays back contents that are compatible with Dolby Digital or DTS and the unit is in the HDMI mode.
    Check the following.
    ・The DVD/BD player is compatible with Dolby Digital or DTS.
    ・The audio output setting of the DVD/BD player or the TV is set to Pulse Code Modulation(PCM).
    ・The TV is compatible with Dolby Digital or DTS.
