Article ID : 00169513 / Last Modified : 25/05/2022
The indicator does not light up, even though DSEE HX or DSD Remastering is set to ON
    The DSEE HX indicator does not light up even though DSEE HX is set to ON.
    [A]: DSEE HX indicator
    If an incompatible input signal is received and DSEE HX is set to ON, the DSEE HX indicator lights up and turns off immediately.
    DSEE HX works only with the following formats:
    Sampling frequency
    Bit depth
    PCM
    (Pulse Code Modulation)
    32 kHz16, 24, 32
    44.1 kHz16, 24, 32
    48 kHz16, 24, 32
    88.2 kHz16, 24
    96 kHz16, 24
    176.4 kHz16, 24
    192 kHz16, 24
    352.8 kHz16, 24
    384 kHz16, 24
    The DSD RE. indicator does not light up even though DSD Remastering is set to ON.
    [B]: DSD RE. indicator
    DSD Remastering is only available with the PCM format signals. DSD Remastering does not work on the DSD format signals.
