Article ID : 00168007 / Last Modified : 05/01/2017Print
What headphones does the device support?
    Can I use headphones with the noise canceling function?
    Can I connect to more than one terminal?
    The headphones supporting the device are as follows.
    Balanced standard (4.4mm in diameter), 3-pole mini (balanced connection, 3.5 mm in diameter) x 2, XLR4 (balanced, 4 pins), Standard (6.3 mm in diameter), Stereo mini (3.5 mm in diameter)
    For US Region:The impedance of headphones corresponds to 12-600 ohm.
    For Other Region:The impedance of headphones corresponds to 8-600 ohm.
     [A]
     XLR4 headphone jack  balanced 4 pins  Image
     [B]   Stereo mini headphone jack  3.5 mm in diameter  Image
     [C]   Standard headphone jack  6.3 mm in diameter  Image
     [D]   Balanced standard headphone jack  4.4 mm in diameter  Image
     [E]   3-pole mini headphone jack  3.5 mm in diameter  Image
    NOTE:
    • Sound cannot come out simultaneously from two or more jacks. The sound comes out only from the headphone terminal selected in OUTPUT or PRE OUT terminal.
    • Although headphones with the noise canceling function are available for use, noise may be heard when you are playing the DSD signal.
