Article ID : 00156513 / Last Modified : 23/08/2016Print
The projector does not project images even when it is placed in “HDMI” mode using the dedicated app for mobile devices
    If you are unable to project images in HDMI mode, please check the following items:
    • If the message “No Wireless unit found” is displayed on the LSPX-P1 projection screen or the dedicated app:
      • Make sure that the Wireless unit is correctly plugged in
      • The distance between the Wireless unit and LSPX-P1 may be too long. Bring them closer to each other
    • If the message “No input from HDMI.” is displayed:
      • Make sure that an HDMI cable is correctly connected to the Wireless unit’s HDMI IN connector
      • Make sure that the HDMI output device connected to the Wireless unit is turned on and set correctly to output HDMI
    • When LSPX-P1 projects nothing:
      • Make sure that the image output from the HDMI output device is not a black screen image.
        On the dedicated app for mobile devices, select [Poster] once, then select [HDMI] again.
      • Restart LSPX-P1 and the Wireless unit (press and hold the power button to restart LSPX-P1)
