Article ID : 00156456 / Last Modified : 23/08/2016Print
The connection using Miracast (Screen Mirroring) is unstable or unable to connect
    Depending on the use environment, the video or sound may be intermittent or stop. Make sure your Wi-Fi signal is strong both on your casting device and the projector. Also make sure all devices are updated to the latest firmware available.
    NOTE: Although this unit complies with the Miracast standard, connectivity with all devices is not guaranteed.
    For instance:
    • A computer installed with Windows 8.1 and compatible with HDCP 2.1 or earlier cannot establish a Miracast connection
    • A computer installed with Windows 8.1 and compatible with HDCP 2.2 may be able to establish a Miracast connection when Windows Updates have been installed
