Article ID : 00125477 / Last Modified : 12/02/2026Print
Why is Location information necessary for Sony's Android TV?
    Services offered by Google (as well as some third-party applications) use location information to optimise their services for each country. Depending on the application, if you do not enable a Location, the app may not work properly.
    If disabling the Location setting causes issues, follow the steps below to turn on Location:
    1. Set the Location status to On or Use Wi-Fi to estimate location.
      1. Press the HOME button on the remote control.
      2. Select Location in the Personal category.
      3. Select Location status and set to On or Use Wi-Fi to estimate location.
    2. Set Location in Restricted Profile to True.
      * This step is only necessary if you are using a Restricted Profile.
      2. Select Security & restrictions in the Personal category.
      3. Select Restricted Profile.
      4. Select Settings.
      5. Select Allowed apps.
      6. Select Settings.
      7. Select Location and set to True.
    For further information, visit the Android TV Help page, then search Android TV location
    NOTE: The TV does not have a GPS module, but location information can be estimated from Wi-Fi or network information.
