Article ID : 00152755 / Last Modified : 23/06/2017
How can I check which version of Music Center (SongPal) I currently use?
To check which version of Music Center (SongPal) you are currently using, follow the below procedure:
  1. In the Speaker & Group screen, tap the drop-down menu icon in the top-right corner of the screen
  2. Select About
  3. Your current version will then be displayed as the first menu item
