Article ID : 00123941 / Last Modified : 25/05/2022Print
How can I remove audio devices or groups from the Music Center (SongPal) app?
    In order to remove speakers, other audio devices or groups from the Music Center (SongPal) app, follow the below procedure:
    1. In the Speaker & Group screen, tap the drop-down menu icon in the top-right corner of the screen
      Dropdown
    2. Then, select Remove Speakers
      Dropdown
    3. Finally, place a tick next to the speakers you wish to remove, and tap REMOVE
      Dropdown
    4. Press OK to remove the audio device or group.
      Delete
