Error: The service cannot be accessed at this time; reference code 40
When I access Berliner Philharmoniker Digital Concert Hall, an error code appears on the screen and I cannot use it.
Try to change the setting by following the steps below.
- Press the HOME button on the AV Receiver to open the HOME menu.
- Select Settings.
- Select Parental Control Area Code in the Internet Services Settings category.
- Check that your country is selected.
- If the setting is changed to a setting other than your country, select your country again.
