Article ID : 00159710 / Last Modified : 16/01/2026Print
    How to adjust the volume of a Bluetooth device paired with the Blu-ray Disc Player.
    Follow the steps below to adjust the volume of a Bluetooth device paired with the Blu-ray Disc Player.
    IMPORTANT: Before you proceed with the steps below, verify whether the Bluetooth device is successfully paired with the Blu-ray Disc player .
    1. While the Blu-ray Disc player is on playback mode, press the OPTIONS button on the supplied remote control.
    2. Select Bluetooth Volume.
    3. Press UP ARROW button Image orImage DOWN ARROW button to adjust the volume of the connected Bluetooth device.
    NOTE: Some Bluetooth devices may not support volume adjustments via Bluetooth connection. In this case, adjust the volume from the Bluetooth device itself.
