Article ID : 00151348 / Last Modified : 16/01/2026Print
    What do the colors and the flashing of the LED (On/standby indicator) on the subwoofer mean?
    The table below shows what the colours of the flashing LED (On/Standby indicator) of the subwoofer mean.
    Type of FlashesGreenOrangeRed
    Lit
    • The power is on.
    • The SECURE LINK connection is active.
    • The power is on.
    • The power is off.
    • The subwoofer is in standby mode.
    Flashes
    Indicates a rise in temperature of the subwoofer. Follow the steps below to resolve this:
    1. Turn off the subwoofer and make sure that nothing is blocking the vent.
    2. Unplug the power cord from the wall outlet.
    3. Wait for a few minutes until the temperature has cooled.
    4. After the temperature has cooled, plug the power cord back in.
    5. Turn on the subwoofer.
    Flashes slowly
    The SECURE LINK connection is in standby even when there's no signal. The SECURE LINK connection is in standby even when there's no signal.
    Flashes quickly
    For HT-ST9, HT-NT3 and HT-RT5, the unit may need repair.
    Periodically flashes quickly
    The SECURE LINK connection is in progress, wait until it's established.
    If you struggle with wireless connection issues
    Follow these instructions if you encounter an issue with the wireless connection:
    • Move the subwoofer closer to the central unit of the home theatre.
    • If possible, place the subwoofer where it isn't directly blocked by any furniture, walls, or metal barriers.
    • Move your wireless router more than one meter (3 feet) away from the central unit, subwoofer, or sound speaker.
    • If the wireless router can switch between 2.4 GHz and 5 GHz frequency bands, try the other frequency.
      • For the HT-ST9, HT-ST5, HT-NT3, HT-RT5: Try switching the wireless router to the 2.4 GHz band.
      • For the HT-CT780, HT-CT380, HT-NT5, HT-CT790, HT-CT390, HT-XF9000, HT-X9000F: Switch the wireless router to the 5 GHz band.
    • If the wireless router has multiple channels, set it to a different channel. If the connection issue is resolved, save the setting for that channel.
      • Check the router manual for details on how to change the channel.
      • If the instructions aren't clear, restart the router. It may automatically select another channel when it turns back on.
