Article ID : 00159338 / Last Modified : 25/05/2022Print
How to connect the DualShock 4 controller to a Blu-ray Player
    IMPORTANT: Blu-Ray Disc players support only one DualShock 4 controller connection at a time. The controller must be connected via a USB cable.
    1. Connect the DualShock 4 controller and the Sony Blu-Ray Disc player’s USB port using a standard micro USB cable.
    2. If the DualShock 4 controller’s light bar is solidly lit up, then the controller is ready to use via USB.
    NOTE: The DualShock 4 controller must remain connected via USB to be used. It will not function wirelessly.
