Article ID : 00144073 / Last Modified : 16/01/2026Print
    How to stop HDD recording
    Use any of the following methods to stop recording.
    Using the infrared remote control:
    1. Change to the broadcast that is currently being recorded.
    2. Press the STOP button on the remote control.
    Using the Touchpad Remote Control:
    2. Press the Action Menu button on the remote control.
    3. Select REC STOP.
    From the Home menu:
    1. Press the HOME button on the remote control.
    2. Select Program Guide in the Apps category.
    3. Select Timer list.
    4. Select the broadcast that is currently being recorded.
    5. Select Rec Stop.
