Article ID : 00128485 / Last Modified : 25/08/2015Print
Unable to start the Screen mirroring feature.
    Screen mirroring is a feature that allows you to display the screen of a compatible device (tablet, phone, etc.) on your television screen.
    NOTE:
    • This feature uses Miracast technology to create a direct wireless connection between your device and  AV Receiver. Your device must support Miracast (Screen mirroring) for this feature to work.
      To confirm if your device is a Wi-Fi Certified Miracast device, visit the website below.
      http://www.wi-fi.org/discover-wi-fi/wi-fi-certified-miracast
    • Screen mirroring does not use your wireless home network.
    • While you are using Screen mirroring, your device's connection to your home network will be turned off.
    • Apple products are not compatible with Miracast (Screen mirroring) technology.
    Follow the steps below to use Screen mirroring:
    1. Press MIRRORING.
      You can also select Watch - Screen mirroring from the home menu.
    2. Open the Screen mirroring application on your remote device.
    3. Follow the on-screen instructions.
      Activate the Screen mirroring function from your mobile device.
      NOTE: For details on how to activate the function, refer to the operating instructions supplied with your mobile device.
